Venkat_96088's avatar
Venkat_96088
May 04, 2011
Issue with Custom Trap for specific node
I have used a custom trap for a specifc node after which the Node status logs are not seen in default log location var/log/ltm
After removing custom trap config, still not able to veiw any of the logs in var/log/ltm,
Custom traps looks like this in config/user_alert.conf file,
alert BIGIP_MCPD_MCPDERR_NODE_ADDRESS_MON_DOWN "Node 1.1.1.1 monitor status down."{ snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.12" }
The only logs which are visible as below,
May 3 05:46:23 ***** alertd[1986]: 01100043:5: logcheck Notice:Disconnect mcpd 0
May 3 05:49:51 ***** alertd[27426]: 01100043:5: logcheck Notice:Disconnect mcpd 0
May 3 05:50:58 ***** alertd[29120]: 01100043:5: logcheck Notice:Disconnect mcpd 0
May 3 07:33:21 ***** alertd[30739]: 01100043:5: logcheck Notice:Disconnect mcpd 0
May 3 08:04:08 ***** alertd[15285]: 01100043:5: logcheck Notice:Disconnect mcpd 0
What did i do wrong? How do i set it back to default var/log/ltm?
Please advise..
