Nirav_67406
Sep 29, 2014Issue with configuring oracle as pool member
Hi Team
I want to verify the receive string got by the F5 LTM. I am using monitor which uses -> defaults-from /Common/oracle
For https mostly I use curl command and I get the receive strings. But what can we use as a troubleshooting tool for oracle monitor ?
- The_Bhattman
Hi Nirav,
Did you try using tcpdump?
- Nirav_67406
I figured it out . For oracle queries like 'jbdc' you can use the debug option . Which gives pretty much all that you require!!
