s3s1277_111291
Jan 24, 2013Issue with class match
on version 10.2 LTM, I am trying to add this irule and its' failing with below error. i have no doubt i am missing something very simple. can someone help?
error: line 3: [can't find value_list] [class match $srcip equals class1
b class class1 list
class class1 {
host 10.1.1.1
host 10.1.1.2
when CLIENT_ACCEPTED {
set srcip [IP::client_addr]
if { ! [class match $srcip equals class1] } {
pool pool1
log local0. "$srcip didnt match."
else {
log local0. "$srcip matched."
pool pool2
- What_Lies_Bene1
I'm not sure it's a good idea to call a class class1, I'd suggest you rename it! If that doesn't make a difference, remove the variable throughout, for example, for the first line;if { not [class match [IP::client_addr] equals source-ips] } { ... - s3s1277_111291
Thanks for the reply. I tried both. Renaming the class, and also not using variable. And still got the same error. - s3s1277_111291
sorry, my mistake.. i had a typo. this is resolved. - sdoremus33_8277
class class1 {
host 10.1.1.1
host 10.1.1.2
try this
class class1
host 10.1.1.1
host 10.1.1.2
