kumar_gaurav_32's avatar
kumar_gaurav_32
Feb 05, 2018
ISSUE WHILE CONFIGURING HA IN F5 LAB
Hi all,
I am configuring HA in my F5 lab. F5 virtual addition is 13.0.0 build 0.0.1645 final. In both the devices HA vlan is configured in the same network. But they are not pingable. So the status of Device is ONLINE(ACTIVE)/Disconnect. Please suggest but to do.
  • Surgeon's avatar
    Surgeon
    Ret. Employee
    Check your virtual network config. It looks like you are missing something. Check arp table and if there is no arp record for the peer device then this questions need to be address to virtualization team since L2 network is not working
  • Hi Kumar,
    Could you please check your HA vlan's IP addresses Port Lockdown setting? It should be setted as "Allow Default" or "Allow All".
