Graziano_Rizzat
Nov 26, 2007Historic F5 Account
issue to match datagroup string value with URI variable
Hello,
The irule we are working on is a simple redirect to https when there is a match between uri user request and string on data group.
Unfortunatly something on the matching statement is wrong because there isn't a match even if the user uri request is the same as the datagroup string. Here is the irule:
class urilist {
"/px/"
rule test-plugin {
log local0. "requested host is [HTTP::host] uri starts with [HTTP::uri]"
if { [HTTP::uri] starts_with $::urilist}{
HTTP::redirect "https://[HTTP::host][HTTP::uri]"
else {
log local0. "requested uri is not into the datagroup [HTTP::uri]"
log local0. $::urilist
pool pool-www.farm
Log messages when user ask for /ag/ uri:
Nov 26 17:47:59 bigip1 tmm[1095]: Rule test-plugin : requested host is test.www.farm.csebo.it uri starts with /ag/
Nov 26 17:47:59 bigip1 tmm[1095]: Rule test-plugin : requested uri is not into the datagroup /ag/
Nov 26 17:47:59 bigip1 tmm[1095]: Rule test-plugin : {/px/}
Log messages when user ask for /px/ uri:
Nov 26 17:48:04 bigip1 tmm[1095]: Rule test-plugin : requested host is test.www.farm.csebo.it uri starts with /px/
Nov 26 17:48:04 bigip1 tmm[1095]: Rule test-plugin : requested uri is not into the datagroup /px/
Nov 26 17:48:04 bigip1 tmm[1095]: Rule test-plugin : {/px/}
Your help will be appreciated
- hoolio
The rule and class look fine. I wonder if this is an oddity withe the starts_with comparison. Do you get the same problem if you make a request for /px/test or anything else that starts with /px/ but is longer?
Aaron - Andrea_102213
I try with a longer uri but the response is always the same; it seems that the test doesn't read the class urilist!!
In fact, I try with another iRule in which I don't use the class urilist but the test include directly "/px/", like this:
if { [HTTP::uri] starts_with "/px/"}
and in this way works correctly. But this in not the solution!!
Thanks in advance - Andrea_110925
Right.
Thanks a lot.
