issue in irule and data group list
version is 11.0
I follow the "ltm_concepts_guide_v11_0" and try to test the data group list.
the sample is as below
when CLIENT_ACCEPTED {
if {[matchclass [IP::remote_addr] equals $::aol]}{
pool tw_proxy_slb_pool
And i add my client subnet in default data group file "aol"
the test result is fail.
the error message is as below
TCL error: /Common/test_data_group - can't read "::aol": no such variable while executing "matchclass [IP::remote_addr] equals $::aol"
any idea?
- nitass
Employee
can you try this?
if {[matchclass [IP::remote_addr] equals aol]}{
or
if {[class match -- [IP::remote_addr] equals aol]}{ - Arie
Altostratus
Since you're running v.11 you will want to use "class match" instead of "matchclass", since the latter is a deprecated command.http://devcentral.f5.com/wiki/iRules.class.ashx
- George_Watkins_Historic F5 Account
Another thing worth mentioning is that as of version 9.4.4, you should no longer address datagroups using "$::" or "::". Check out this thread as well:
https://devcentral.f5.com/Forums/tabid/53/aft/1176472/Default.aspx
-George
- Michael_Yates
Hi RyanTseng,
Arie is correct. You should be using class match if you are in v11.x.x.
You will also need to drop the "$::" and/or "::" Global Variable Identifiers since they are no longer necessary as of v10.x.x. You can read more about that here: v.10 - A new iRules Namespace
Hope this helps.
