marlon_Gino-gi1
Sep 26, 2008Is there any way to mirror UIE persistence to the pair of load balancer; how about fail-over?
hello Guys,
would just like to know if there is a rule to mirror the UIE persistence table that was created using an IRULE to the standby unit of F5 box so that when failover occurs, the persistence table that was created using an Irule on the active unit is also replicated on the standy unit.
thanks in advance
- hoolio
I'm not certain, but if you enable persistence mirroring on a custom universal persistence profile and add that to the VIP the rule is used on, it might work.
Aaron
