T33_94464
Jul 01, 2016Is there any way to enforce archive encryption 11.6
Hi DevCentral,
I was looking for a method similar to that in TMOS ver 10, where you could enable Archive Encryption enforcement by default, thus all users would save archives in an encrypted form. I have looked through the TMOS 11.6 configuration and not seeing an option for same. Is there any way to enable this feature?
Many thanks
Unfortunately, this feature sounds to have disapeared. You can check a similar post here : Saving a UCS prompts me for a password
You may ask to Ossar if it's case opened with F5 support has solved his problem
