Is there any way to configure health monitor in below scenerio ?
Is there any way to monitor the Applications server through f5 which are not immediate behind the f5 device ?
Scenerio :
Client ------------> F5--------->Webservers -----------> Application server
Client : User machine, f5 : LTM, Webserver : Backend server which configured on f5 with ports, Application server : Not directly connect with F5, directly connect with Webservers
So is there way to monitor both Webservers & Applications through f5, if any one goes down completely f5 will come to know & change the status of their VIP ?
Thanks Ankit Katyal
- tatmotiv
Best way would probably be to monitor some resource on the webserver that indirectly contains the status of the application server, for example (if application is a java server like tomcat) some custom jsp page that checks the availabilty of the tomcat and returns something like "all OK" via the webserver.
- Vijay_E
Cirrus
Use something like this for "Send String":
GET /index.html HTTP/1.1\r\nHost: host.domain.com\r\nConnection: Close\r\n"Response String" should be a unique value in the content. If the "Response String" somehow depends on your application performance/uptime, you will end up monitoring the application availability.
Reference link.
