JustinH's avatar
JustinH
Jan 03, 2018
Is there a way to configure the F5 client to be set forcefully to Auto Connect mode?
We have users that keep their company laptops in Connect mode while in the office and don't realize they are on VPN. We have constantly informed them to keep it set to Auto connect as we have it set to recognize our network and not connect if you are on it. So we are trying to see if we can force this some how besides deleting the config file out at start up so it is recreated using the default which is set to Auto Connect. If there is no other way to do this, can this be incorporated in to the client soon?
Thank you in advance, Justin
  • I don't think there is a way to force autoconnect, though you may be able to setup your network so the VPN client does not work when used inside your network, which would require users to disconnect to access resources.
