Eddie_Lau_16940's avatar
Eddie_Lau_16940
7 years ago
Is there a way for an iRule to read a default pool parameter from an unrelated, arbitrary virtual server?
Is there a way for an iRule to read arbitrary config parameters about other virtual servers? Specifically, I have an iRule that needs to read the default pool parameter from another virtual server of a different type.
If this isn't possible, can an iRule on one virtual server write its own default pool value to a file or local database that another iRule can read from?
  • Eddie,
    It is possible to write data about a virtual server to the cache and retrieve it from other iRules, though it's a bit unorthodox. Perhaps it isn't the most optimized but here is an iRule I wrote that should cache the pool name of the virtual server given in the first item of the URI. For example, "https://example.com/testvip/uri" would log out the default pool member of the virtual server named "testvip".
    when CLIENT_ACCEPTED
        table set "[virtual name]" "[LB::server pool]" 864000
    when HTTP_REQUEST
        set vip_name "/Common/[lindex [split [HTTP::uri] "/"] 1]"
        if {[table lookup $vip_name] eq "" }
            log local0. "No records for this vip, try connecting to it first"
        else
            set pool_name [lindex [split [table lookup $vip_name] "/"] 2]
            log local0. "Pool for $vip_name is $pool_name"
    Do note that you must connect to the virtual server first so that it may cache its data, then you will be able to access that information from other virtual servers. I also set the cache lifetime to 10 days, so if a virtual server is not connected to for that amount of time, it will lose its cached data and you won't be able to access information about that virtual server from other virtual servers.
    If you have any modification requests or questions, I am sure I can help.
