Robert_Decker_2
Mar 22, 2006Is it possible to use LDAP and OCSP?
Can a rule be created that references an LDAP username and password or OCSP client cert? Every attempt I've tried doesn't seem to work. OCSP Auth section doesn't seem to like the HTTP::respond syntax, while the LDAP Auth section doesn't seem to like the HTTP::redirect command. Do you have any examples of this working in an Irule?
Thank you very much,
Rob
- Colin_Walker_12Historic F5 AccountWell, for starters, there's an example of an iRule that's been tested succesfully with ldap in the codeshare: Click here
There's also an example of an iRule using multiple authentication methods (LDAP and radius) in the forums, here: Click here
Hopefully those will get you started. I believe there are some more examples in the forums if you do a search for ldap or ldap auth.
-Colin
