vmoseley_96930
Jun 15, 2016Is it possible to perform an antivirus check when using citrix receiver?
I'm using APM client-side check for citrix users and traditionally they've used a browser to connect to APM which is able to do the AV check. I now want users to start using citrix receiver through APM but it fails the AV check. Is there a way i can get this to work with receiver? Many thanks.
- Arnaud_Lemaire
Employee
Hello, for AV checks to work you need to have F5 components on the client side either using portal mode or edge client. if you are just using receiver in proxy mode on APM there is no F5 component on client side.
