CHNAG-SUH_PARK_
Jan 29, 2007Is icontrol possible collect connection recorde?
I want know that the command BIG-IP LTM can make same result of CLI "b conn" in icontrol.
- Well, the answer is "yes" and "no". In 9.x we removed the LocalLB.Connections interface from the public SDK due to the fact that it caused customers issues in the previous revisions because of it's possibly very large result set.
That was the "no" part of the answer. The "yes" part is that the WSDL and handling code is still present on the devices and you can still use it but we do not officially support it at this point as the interface will likely change in the future to accommodate a paging scheme. You can find it in the System.Connections.WSDL file located on the BIG-I if you dare, but I wouldn't recommend it for a high traffic site.
If you need this interface, then I would suggest you contact our support department and submit a feature request to build the paging features and re-enable the interface.
-Joe
