niboto_335022's avatar
niboto_335022
8 years ago
is F5 acting as a proxy for IP forwarding VS?
F5 LTM is described as full proxy. I understand that the following data path between my client, the F5 and the server for TCP trafficis as follow: we have 2 TCP connections where F5 ends the TCP1 connection and F5 establishes a second TCP connection (TCP2) toward the server. (as pictured below)
client--(TCP1)---F5---(tcp2)------server
This is true for a majority of virtual server types such performance L4, standars and performance HTTP.
But what about forwarding IP and forwarding L2? do we still have the path with 2 TCP connections or is the F5 acting as a simple router with the following data path: client--(TCP1)---F5---------server
thanks
  • With a forwarding virtual server, packets are forwarded like a router. However by default this is only for the first SYN packet, to forward traffic mid-flow you'll need to configure Loose Initiation in the TCP profile for it to act more like a router.
