Is ASM right for a very slow "Brute Force"
Hi Guys
I have an application that is being 'brute forced', but not in what I would call in a 'traditional' sense. We have large amounts of logins, in excess of thousands, simultaneously to unique accounts, some valid account some not, from a large number of different IPs, some contiguous IPs/ranges some not.(I have an extensive list of IP's)
However this happens infrequently and not frequently enough to use the Brute force Profile, I would have thought? As it is one mass login attempt to multiple accounts and then nothing for day or so.
All "logins" are coming from the same User agent:
Mozilla/5.0 (Windows NT 6.2; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.81 Safari/537.36
Any ideas on how to go about mitigating this type of attack? IP Intelligence?
I am really new with the security side of things so I apologise if I am asking some simple questions, or not explaining the issue correctly.
- Stephan_Mierau
Employee
IPI could help in this case. Another option could be to use the APM in front of your server and using captcha.
- Stephan_Mierau
Employee
you could try to increase the Measurement Period from the Dynamic Brute Force Protection, but the max value is 60 seconds. Not very long. Maybe an irule counting the false logins, if countable
Using ASM, you can leverage IP Intelligence, Brute Force protection or the DoS profile (really cool in v12.1.0)
Alternatively, I can suggest you using an irule to protect against brute force like this one (need to change peaces of code to fit the authentication method used by the backend) : DoS and NTLM Brute force protection for HTTP(s) flow
Or you can also write an irule to grap credentials and play them seemlessly against APM to create an APM session or deny access : ACCESS::policy evaluate -sid -profile [ +]
You can see an example here : ACCESS::policy
Hi Russel,
I've writen in the past a traditional prä-auth / reverse proxy iRule, which included:
Normalization of username strings (e.g. removing CaSe, different representation of a single username, etc.).
[table] based serialization of parallel login request for a single username spanning multiple TCP connections (to avoid race conditions, while waiting for AAA decissions)
[table] based backlogging of parallel login request with identical credential sets.
[table] based tracking the number of wrong login attemps per user-account, with the added ability to rember and supress attemps using already proven as wrong credentials (e.g. to avoid accidential lockouts caused by the user themself entering old passwords or just using a wrong keyboard layout)
[table] based tracking the number of wrong login attemps per IP address, with some added logic so that a single IP address needs to bruteforce multiple useraccounts before getting locked.
The repository access was implemented using [SIDEBAND] HTTP request directly to the published webservers (e.g. via BASIC or Forms auth) and included a [table] driven SSO mechanism to SSO to multiple websites (also including Cross-Domain-SSO).
If the lockout counter for a specific username has been reached a given limit, further authentication attemps from the same user would be supressed/denied for a given timeframe.
If the lockout counter for a specific IP adresss has been reached a given value, further authentication from the same user would be supressed/denied for a given timeframe.
Hope this helps to get some ideas, what could be done without Catcha, APM or IPI but instead using plain iRules.
Cheers, Kai
- Russell
Thanks again to all the guys that gave answers, will feedback once we come to a decision and let you know how it turned out.
