Matt_108113's avatar
Matt_108113
Mar 10, 2009
IRules setting for http redirect then rewrite response
I am working with Oracle istore behind an F5 and basically we are trying to use the F5 as a reverse proxy and do something like this.
customer url: http://istore.cust.com
actual oracle istore url: http://hostname:8000/OA_HTML/ibeCAcdLogin.jsp?a=b
I wrote a rule to make the F5 forward requests from the customer to the actual url, but the customer sees the http://hostname:8000/OA_HTML/ibeCAcdLogin.jsp?a=b as the response of the redirect. How can I clean this up to make it pretty to the customer? I would like the customer to either only see the page as http://istore.cust.com or http://istore.cust.com/OA_HTML/ibeCAcdLogin.jsp?a=b but not as the actual hostname with the port 8000.
here is what I have for irules so far:
HTTP::redirect "http://hostname:8000/OA_HTML/ibeCAcdLogin.jsp?a=b"
  • hoolio's avatar
    hoolio
    Here is an example which allows you to proxy an external site to an internal one by updating the domain in the requested host header and in the response Location header:
    iRule to change host headers
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=1991719925 (Click here)
     when RULE_INIT {
         Set the hostname that the client makes request to (do not include protocol)
        set ::external_hostname "www.mycompany.co.uk"
         Set the hostname that the BIG-IP will rewrite requests to
        set ::internal_hostname "www.provider.com"
         Log debug messages to /var/log/ltm? 1=yes, 0=no.
        set ::proxy_site_debug 1
        if {$::proxy_site_debug}{log local0. "Received request from [IP::client_addr] -> [HTTP::host][HTTP::uri]"}
        if {$::proxy_site_debug}{log local0. "Rewriting [IP::client_addr]'s Host header to $::internal_hostname"}
         Rewrite the Host header
        HTTP::header replace "Host" $::internal_hostname
     when HTTP_RESPONSE {
         Check if the status indicates a redirect
        if {[HTTP::is_redirect]} {
           if {$::proxy_site_debug}{log local0. "Rewriting [IP::client_addr]'s redirect to \
     [string map -nocase $::internal_hostname $::external_hostname [HTTP::header Location]]"}
            Rewrite the Location header replacing the internal hostname with the external hostname
           HTTP::header replace Location [string map -nocase $::internal_hostname $::external_hostname [HTTP::header Location]]
    Or if you want more complete functionality, take a look at the ProxyPass iRule in the Codeshare (Click here).
    Aaron
  • Hello Matt,
    Did you get this working ?? I have a similar request and looking for irules to get this done..
    Thanks SHivam
