Ricardo_Raza_14
Mar 10, 2014iRules for DDOS and DNS
Hi, please I need to configure the following parameters: - Packet identification number - Fragment offset - Ports number - TCP sequence parameters and for DNS I need to configure - DNS ID - DNS query count - DNS query - NAPTR
I need to configure this parameter for LTM, AFM analize this parameters, I think that I can do this with iRules, is this possible? And please can you help me with the iRule for this parameters?
Thanks for your help
- Mohamed_Lrhazi
Altocumulus
Please clarify what you mean by "need to configure the following parameters". You want to write an iRule that would inspect DNS packets, then do what to them? if X and Y or Z and W, then ... - Christian_30338Historic F5 Account
Hi can you also confirm what licenses apart from LTM you are running on the device? DNS Express for example?
- Ricardo_Raza_14
Hi, I only have AFM, and LTM
- Ricardo_Raza_14
Hi thats correct I need an iRule that would inspect DNS packets, but in the technical specifications the device have to satisfy the items that I mentioned in the previous comment
