Spela_317265's avatar
Spela_317265
Aug 29, 2018
iRule $variable problem
I have a problem with writing an iRule ... In the HTTP header I should have a variable called "$STH", and then the problem arises... TCL treats the dollar symbol as a symbol for the variable. What can I do in this case?
HTTP :: header insert "$STH" '523' }
Best regards, Spela
  • You mean the name actually contains the dollar sign ($)?
    If so, you'd need to escape it:
    HTTP :: header insert "\$STH" '523'
