"IRULE" using IP and FQDN
Hello, I have question on “irule” for whitelisting. Currently we’re using IP as source or destination and that is working correctly as mechanism for directing traffic towards bypass path. The question is – how (if) we can add FQDN (or actually entire domains i.e. Microsoft – related to Office 365 and Skype for Business as example) on the top of IP listings? Regards
- Jarek_Twardowsk
Just to clarify, here is the irule that we're using based on IP. How this can be modified to include FQDN or domain as destination.
when RULE_INIT {
Debug logging level (0 = logging disabled, 1 = logging enabled) set static::_proxy_bypass_debug 0 Proxy Bypass Source IP datagroup name (as configured under Local Traffic > iRules > Data Group List) set static::source_ip_proxy_bypass_RD1_dg "/Common/source_ip_proxy_bypass_RD1_dg" Proxy Bypass Destination IP datagroup name (as configured under Local Traffic > iRules > Data Group List) set static::destination_ip_proxy_bypass_RD1_dg "/Common/destination_ip_proxy_bypass_RD1_dg"}
when CLIENT_ACCEPTED {
If client IP is in bypass list then don't load balance client to ironports, otherwise load balance to default pool. if { not (([class match [IP::client_addr] equals $static::source_ip_proxy_bypass_RD1_dg]) || ([class match [IP::local_addr] equals $static::destination_ip_proxy_bypass_RD1_dg])) } { if { $static::_proxy_bypass_debug } { log local0. "Client connection proxied to ironports. Client Source IP [IP::client_addr] or Client Destination IP [IP::local_addr] is not in Datagroups. Server selected is [LB::server]" } return } else { if { $static::_proxy_bypass_debug } { log local0. "Client connection not proxied to ironports. Client IP [IP::client_addr] or Client Destination [IP::local_addr] is in Datagroups." } forward} }
- svs
Just add a datagroup containing the hostnames and use [HTTP::host] as additional match condition in your "if".
if { not (([class match [IP::client_addr] equals $static::source_ip_proxy_bypass_RD1_dg]) || ([class match [IP::local_addr] equals $static::destination_ip_proxy_bypass_RD1_dg]) || ([class match [HTTP::host] equals $static::destination_fqdn_proxy_bypass_dg])) }I didn't test this, but it should work.
