Abed_AL-R_26070's avatar
Abed_AL-R_26070
Jul 12, 2018
iRule URI matching issue
Hi
I'm trying to match first term but whatever I do it is not match
    this iRule check the URI and sends the request to the appropriate pool
        if { [string tolower [HTTP::uri]] starts_with "/lmsserver" } {
        pool PLMS_Pool
        event disable
        if { [string tolower [HTTP::path]] starts_with "/oauth" } {
        pool PLMS_Pool
        if { [string tolower [HTTP::path]] starts_with "/lms/sso" } {
        set [http::path "/lmsserver"]
        pool PLMS_Pool
        if { [string tolower [HTTP::path]] starts_with "/lms/rest/ext/oauth2/token" } {
        pool PLMS_Pool
        if { [string tolower [HTTP::path]] starts_with "/dtpcms" } {
        pool PLMS_Pool
        if { [string tolower [HTTP::path]] starts_with "/httppush" } {
        pool Push_Pool
        if { [string tolower [HTTP::path]] starts_with "/admin" } {
        pool PTEACH_Pool
        if { [string tolower [HTTP::path]] starts_with "/lms" } {
        pool PTEACH_Pool
        if { [string tolower [HTTP::path]] starts_with "/rsp" } {
        pool PTDWH_Pool
        if { [string tolower [HTTP::path]] starts_with "/dwh" } {
        pool PTDWH_Pool
        if { [HTTP::uri] equals "/" } {
        HTTP::redirect "http://[HTTP::host]/lms"
        pool PTEACH_Pool
If I go to /lmsserver instead of mapping me to PLMS_Pool , it is mapping me to PTEACH_Pool
why is that ?
  • Hi,
    Your problem is that you not set a oneconnect profile.
    Please set a OneConnect profile (Default) in your vs then try again.
    Keep in mind that oneconnect allow you to detach connection in server side. You can force the server-side detachment by applying both an HTTP profile and a OneConnect profile to the virtual server, or by using an iRule to explicitly detach the server-side connection after each HTTP request.
    Regards
  • Please try the following iRule, using a switch statement can avoid a lot of repetition (it is also faster than using if). As suggested above a policy may be an alternative. I have added logging to try to determine which conditions are being matched, please test and share the logging outputs, masking any sensitive information if necessary
        switch [string tolower [HTTP::path]] {
            "/lmsserver" -
            "/oauth" -
            "/dtpcms" {
                pool PLMS_Pool
                log local0. "Path is [HTTP::path] selecting pool PLMS_Pool"
            "/lms/sso" -
            "/lms/rest/ext/oauth2/token" {
                pool PLMS_Pool
                HTTP::path "/lmsserver"
                log local0. "setting Path to [HTTP::path] selecting pool PLMS_Pool"
            "/httppush" {
                pool Push_Pool
                log local0. "Path is [HTTP::path] selecting pool Push_Pool"
            "/admin" -
            "/lms" {
                pool PTEACH_Pool
                log local0. "Path is [HTTP::path] selecting pool PTEACH_Pool"
            "/rsp" -
            "/dwh" {
              pool PTDWH_Pool
              log local0. "Path is [HTTP::path] selecting pool PTDWH_Pool"
                pool PTEACH_Pool
                log local0. "Path is [HTTP::path] selecting pool PTEACH_Pool and sending redirect to http://[HTTP::host]/lms"
