tskeel_217567's avatar
tskeel_217567
Feb 23, 2016
irule to restrict ftp and sftp destination
I need an irule to limit sftp and ftp destination ideally by hostname. If hostname is not possible I think IP would be ok.
This was my first attempt:
when CLIENT_ACCEPTED {
  if { !([matchclass [IP::local_addr] equals FTPWhitelist]) }{
    reject
I have one ip in FTPWhitelist but traffic to other sites is allowed.
  • Josiah_39459's avatar
    Josiah_39459
    Historic F5 Account
    I'm very confused. Where are you attaching the irule? To a forwarding vip? Or a vip with a single ip? Does the vip proxy multiple hostnames? Hostname won't be possible unless you do a sideband reverse DNS lookup, because the hostname is resolved by the client and only the ip comes to the BIGIP. Otherwise you can do it the way you are trying, or use packet filters, etc...
  • This is for a forward proxy virtual server. I attached the irule to virtual server with type "standard", I restricted the port and source destinations.
