Peter_Singer_71
Feb 20, 2011irule to redirect on management interface
If a request comes in on the management address port 80 and I want to redirect it to https:// can the redirect be done on the management interface?
How?
Device bigip 5100 version 9.4.8.
Peter
- hoolio
Hi Peter,
I don't think it's possible to use an iRule to redirect traffic on a management IP or self IP from HTTP to the management GUIs HTTPS service. You could modify the httpd.conf, but changes to the daemon conf files can get overwritten during upgrades/hotfix installations. I couldn't figure out a way to do this through the supported bigip_sys.conf include files.
For details on the supported methods to modify system daemon configuration, see this article and the comments:
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/155/LTM-942-Custom-Syslog-Configuration.aspx
If you can't figure it out either, you could always open a case with F5 Support and make a request for enhancement.
Aaron
