Sorin_Rusnac_86
Mar 12, 2008iRule to overwrite Page Extension help!
Hi -
Hoping somebody can help me is there a sample or code i can use to overwrite file extenstions on pages is this possible?
For example what I want the iRULE to do is as follows:
Example: ‘http://ourdomain.com/JDE/TaskExplorer/somelink.JSP’ gets rewritten to ‘http://ourdomain.com/JDE/TaskExplorer/somelink.jsp’
So it will rewrite uppercase JSP to lowercase jsp.
- Nicolas_Menant
Employee
hi,
you should be able to do something like this:
set path_without_extension [getfield [HTTP::path] "." 1]
set extension [string tolower [getfield [HTTP::path] "." 2]]
log local0. "path_without extension is $path_without_extension"
log local0. "extension now is $extension"
set new_path "$path_without_extension.$extension"
log local0. "new path is: $new_path"
HTTP::path $new_path
i added debugging data in case i missed something. Debugging info should be avaiable in /var/log/ltm through the CLI or in system>log>local traffic through the GUI
i may have done an error ^^ - hoolio
In addition to nmenant's example, here are a couple more options:
Here is a version which looks for any two to four character extension in all caps and sets it to lower case:when HTTP_REQUEST { Get the path (/path/to/file.ext) Use URI::basename to get the filename and extension (file.ext). Use getfield to split on the period, getting only the extension (ext). Prepend a period back to make the string more specific. set file_extension .[getfield [URI::basename [HTTP::path]] . 2 ] Log the parsed file extension log local0. "Original file extension: $file_extension" For two to four letter capitalized extensions, update the path with the lower case extension. switch -glob $file_extension { .[A-Z][A-Z] - .[A-Z][A-Z][A-Z] - .[A-Z][A-Z][A-Z][A-Z] { Set extension to lowercase set file_extension_lowered [string tolower $file_extension] Update the path by replacing the original file extension with the lowered case version HTTP::path [string map "$file_extension $file_extension_lowered" [HTTP::path]] Log the updated path (this should be removed when you're done testing). log local0. "Updated path: [string map "$file_extension $file_extension_lowered" [HTTP::path]]" } } }
If you only wanted to update .JSP or any other mixed case of .jsp to .jsp, you could simplify the rule:when HTTP_REQUEST { HTTP::path [string map -nocase {.jsp .jsp} [HTTP::path]] }
The second of the two options would be more efficient.
Aaron - Sorin_Rusnac_86
Thanks guys for all the help, I really appreciate the quick replies your help is much appreciated.
