sam_111661's avatar
sam_111661
Oct 21, 2008
iRule to load balance between 2 pools?
For some reason I can't have all members (running one service) in one pool and so I need to create two pools and load balance (round robin) between them with source persistence. Can this be done using irules?
thanks in advance
  • Hamish's avatar
    Hamish
    Well... You can write almost anything with an iRule, so sure why not.
    But why can't you have all the members in one pool?
    H
  • OK, the application servers (2 servers) do not support bonding / etherchannel but have two interfaces that can be configured in two different vlans so I'm trying to use bigip to achieve this using priority groups.
    Since I don't want to have two IP addresses active on the same server, I can't add them all to the same pool and I need to have each server with it's 2 IP addresses in one pool and have each IP in it's own priority group.
    Now I want RR load balancing between the pools using iRule and was not sure if this is possible
