iRule to detect url and forward port.
Hi, my main iRule use events HTTP_REQUEST with switch style to detect [HTTP::path] then send to each pool it work properly below is work flow front https://domain.com/path/ (443) => mid f5 ssl terminate detect [HTTP::path] then sent to iis pool (80)
but my problem is I need to use this iRule for application socket with specify port but when send request to socket pool it not work below is flow front https://domain.com/path/ (443) => mid f5 ssl terminate detect [HTTP::path] then sent to socket application pool (5001)
This is my iRule sample
switch -glob [string tolower [HTTP::path]] {
"/fristpath/_" {
pool fristpool
"/secpath/_" {
pool secpool
"/socket01/*" {
pool socket01
pool socket01 monitor with TCP node specify port 192.168.51.10:5001 (windows application socket program)
I try to use
"/socket01/*" {
pool socket01 member 192.168.51.10 5001
But seem not work Please help to suggest me how to solve this request thank somuch.
- bhs_114985Historic F5 Account
I would stick with your first example. Couple of thoughts: What is the status of the socket01 pool? Does the server have a route back? (Should you also be using snat) are you sure 5001 isn't expecting ssl? Add some log statements to your rule so you know where you are in the rule when the request is coming in.
- H_Sang_39134
thanks for your reply this is structure - node/pool monitor by http [port 80/5001] and status is green. - please explain more about "route back" - I dont enable SNAT - We use front end with https for encrypt data and dont need to regist new ssl license (shared ssl domain)
Thank and cheer.
Hello,
This shouldn't be any problem at all. Thank you for sharing the architecture it really helps 🙂 Your code is good. Just add the following log statements from my example and you will see the entries in /var/log/ltm.
when HTTP_REQUEST { log local0. "Http path equals [HTTP::path]" switch -glob [string tolower [HTTP::path]] { "/fristpath/_" { log local0. "http path was [HTTP::path] --> Going to fristpool" pool fristpool } "/secpath/_" { log local0. "http path was [HTTP::path] --> Going to secpool" pool secpool } "/socket01/*" { log local0. "http path was [HTTP::path] --> Going to socket01 pool" pool socket01 } } }I tested most of the common variables of the URL's in your examples. Here is my log output:
/Common/Redirect_Path : http path equals / /Common/Redirect_Path : http path equals /fristpath /Common/Redirect_Path : http path equals /fristpath/_ /Common/Redirect_Path : http path was /fristpath/_--> Going to fristpool /Common/Redirect_Path : http path equals /secpath/ /Common/Redirect_Path : http path equals /secpath /Common/Redirect_Path : http path equals /secpath/_ /Common/Redirect_Path : http path was /secpath/_--> Going to secpool /Common/Redirect_Path : http path equals /secpath/_hello /Common/Redirect_Path : http path equals /secpath/_.hello /Common/Redirect_Path : http path equals /socket01 /Common/Redirect_Path : http path equals /socket01/ /Common/Redirect_Path : http path was /socket01/ --> Going to socket01 pool /Common/Redirect_Path : http path equals /socket01/hello /Common/Redirect_Path : http path was /socket01/hello --> Going to socket01 pool - H_Sang_39134
Thank you bhs, FYI, the program was build with C HttpListener class at the backend server.
Right now, iRule script is working fine and the log was show like your suggestion.
Then I have installed the WireShark at backend server but no incoming log show in WireShark.
I point to the iRule does not send the request to the backend server.
- Shain_Singh_846Historic F5 Account
If you are using v11.4+ then I would look into using LTM policies to achieve the desired outcome. http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-concepts-11-4-0/3.html
- H_Sang_39134
Dear All, this problem resoled traffic from public cant to pass to backend server bcz my network team make a misstake to allow http access and this firewall is secret I dont know b4.
thanks you every body and sorry with stupid problem. solved on 7 Sep,2014
