sfracass_83515's avatar
sfracass_83515
Apr 11, 2008
iRule to block networks works, sometimes.....
I just want to block googlebot requests to certain virtual servers at the LTM but this rule doesn't seem to work. Oddly enough, when I change the IP values to block my own internal network subnets at the same virtual servers, it works. I had to block at the router where I could see in the logs the rejection of the IP specified, so I know the IP is coming into my network as expected (not NAT'd).
when CLIENT_ACCEPTED {
if { [IP::addr [IP::remote_addr] equals 60.249.0.0/255.255.0.0] } {
reject
Any help is appreciated.
  • Did you log the value of IP::remote_addr to verify it's correct when googlebot is trying to access it?
    Wouldn't it be simpler to use a user-agent test?
      if { [string tolower [HTTP::header "User-Agent"]] contains "googlebot" } {
        reject
    This would block googlebot from any source network and is very easy to test with the user-agent switcher in FireFox.
    -Joe
  • BUT, Googlebot is a legitimate useragent for organizations with google appliances. We needed to specifically block Google's googlebot.
