Michael_Omaljev's avatar
Michael_Omaljev
Jul 13, 2006
Irule thast does not SSL v2
Looking to create an I-Rule that requires greater then SSL v2, and a minimum of 128 bit encryption
Any help would be appreciated..
thanks
MO
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    If you're looking to get the version and the encryption level, I'd recommend checking into the SSL::cipher version and SSL::cipher bits commands respectively.
    You can read more about them in the iRules Wiki under the SSL section: Click here
    Colin
