Dormelchen_2406
Jan 08, 2013irule redirect, cause of an mobile / tablet connection
hello,
is it possible to create an irule, which redirects mobile devices to another url ?
for example: i call an URL www.test.com from a mobile device such as iphone / windows phone etc. i will be redirect to www.test123.com. otherwise i will be redirected directly to an pool ?
- nitass
Employee
yes, of course. you can check user-agent http header. the following is an example of the similar discussion.
Detecting Mobile Devices and Redirecting to different URL
https://devcentral.f5.com/community/group/aft/2165057/asg/50
