irule POST payload for APM after the assignment is done
Hi, I have an apm configuration which ends with resource assignment. right after the assignment, the backend server replies with a popup banner message. In order to bypass that message, I would like to create an irule that sends a POST with specific payload so that the users will never see that annoying message. There is no way for me to remove that message from the backend server, the only option I have is to do it on F5 APM irule or so. please assist.
thanks.
- stan_piron
Cumulonimbus
Can you check http header differences in first http request and the one after post???
Is there any HTTP cookie added in next requests to inform server you already accept the first banner?
- youssef1
Cumulonimbus
Can yo set this irule in your VS in order to capture response (Popup) then request (Post).
The output will allow you to set the right irule for your need:
https://devcentral.f5.com/codeshare/ultimate-irule-debug-capture-and-investigate-1183
Set the irule header like that:
array set app_arrway_referer { client_dest_ip_port 1 client_cert 1 http_request 1 http_request_release 0 http_request_payload 1 http_lb_selected 1 http_response 1 http_response_release 0 http_response_payload 1 http_time_process 0 }regards
