spalande's avatar
spalande
Jan 08, 2014
iRule not effective for existing connections
We have iRule for server maintenance window, where it will allow only GET requests and block all other requests. This works after applyig iRule to all VIPs. But whoever is already login into the webpage can do POST operations. (may be existing connections???) Is this default behavior where iRule will not come into effect for existing connections? How I can differentiate that it is indeed existing connection before applying iRule is making POST connection using wireshark? what parameters to check and confirm for this?
  • thibino_36264's avatar
    thibino_36264
    Historic F5 Account
    So far as I understand, not only iRules but most of configuration change will not affect existing connections. I do not know how to identify using Wireshark, but checking connection table will help. show /sys connection all-properties
  • hoolio's avatar
    hoolio
    thibino is correct that iRule changes only take effect on new connections.
    You could leave the iRule enabled at all times, but use a data group to store an on|off value. The iRule would use the class command to check the data group key to see if non-GET requests should be blocked.
    https://devcentral.f5.com/wiki/iRules.class.ashx
        Check if the maintenance key is set to on in the maint_dg datagroup
       if {[class lookup "maintenance" maint_dg] eq "on"}{
           Check if this is not a GET request
          if {not ([HTTP::method] eq "GET")}{
              Send an HTTP response with cache control headers set to not cache the response
             HTTP::respond 200 content {Please retry your request later.  Maintenance!} Connection Close Cache-Control No-Cache Pragma No-Cache
    Aaron
    thibino_36264
    Historic F5 Account
    Or if we can identify client IP address for checking, we can filter using | grep
  • I think you want to use a OneConnect profile. Without it, existing connections will not be affected by changes in iRules.
    http://support.f5.com/kb/en-us/solutions/public/7000/200/sol7208.html
        **Content Switching**
    When a OneConnect profile is enabled for an HTTP virtual server, and an HTTP client sends multiple requests within a single connection, the BIG-IP system is able to process each HTTP request individually. The BIG-IP system sends the HTTP requests to different destination servers as determined by the load balancing method. Without a OneConnect profile enabled for the virtual server, the BIG-IP system performs load-balancing only once for each TCP connection.
