hung_105573
Jun 11, 2013IRule monitor node status
Hi all
I a new F5 , pls help me check a irule bellow , i want monitor status of node 1.2.3.4 , at the time , it not work .
when RULE_INIT {
set static::whitelist_ttl "300"
when DNS_REQUEST {
set fqdn [DNS::question name]
if { [ class match [ LB::status node 1.2.3.4 ] eq "up " ] }
pls help me
many thanks
- Kevin_Stewart
Employee
You don't need the class match syntax.
if { [LB::status node 1.2.3.4 ] eq "up " } {
