JRahm's avatar
JRahm
Icon for Admin rankAdmin
Aug 07, 2007
iRule logging issue in 9.4.1 ??
I just upgraded a pair of LTM's to 9.4.1 from 9.1.2 HF5 and I no longer see my iRules (log local0. "xxx") logging to /var/log/ltm, or anywhere else for that matter. I checked to make sure mcpd logging was set to notice, and yet still no irule logs. I thought all logging was impacted, but I see audit logs now have their own file. Is this a no-brainer that someone else has experienced in the move from 9.1.x to 9.4.x, or should I press support? TIA...
Jason
  • hoolio's avatar
    hoolio
    Hey Jason,
    Was your /etc/syslog-ng/syslog-ng.conf file overwritten? Where is local0.info being directed to?
    I haven't seen any issues on 9.4.0 with syslog-ng logging from iRules. By default, any messages containing the string AUDIT should be logged to /var/log/audit. All other local0 messages should go to /var/log/ltm. Here is an example:
    local0.* /var/log/ltm
    filter f_local0 {
    facility(local0) and level(info..emerg);
    destination d_ltm {
    file("/var/log/ltm" create_dirs(yes));
    log {
    source(local);
    filter(f_local0);
    destination(d_ltm);
    audit log /var/log/audit
    filter f_audit {
    facility(local0) and match("AUDIT");
    destination d_audit {
    file("/var/log/audit" create_dirs(yes));
    log {
    source(local);
    filter(f_audit);
    destination(d_audit);
    Aaron
  • Yeah, I checked the syslog-ng config file and all was fine. A /usr/bin/full_box_reboot did the trick. I hate it when my LTM behaves like my PC.
  • Yep, here's my progression:
    bigstart restart syslog-ng
    bigstart restart syslog & bigstart restart syslog-ng
    bigstart restart
    No dice with any of the above.
