Yanik's avatar
Yanik
Dec 17, 2019
iRule issue after an upgrade
Hi Guys !
Does anyone knows a "workaround" for this issue after upgrading from 13.4 to 14.1.2 ?
Upgrade process does not update Tcl scripts Upgrading Tcl scripts (such as iRules). This might cause issues when iRule syntax changes between releases. After upgrading, you might need to modify iRules to reflect any changes in iRule syntax. The upgrade process does not update Tcl scripts (such as iRules) in the configuration. Workaround: None.
Thanks !
  • M_2's avatar
    M_2
    Does the ltm logs show any specific rule that has the issue with the syntax ?
    • Yanik's avatar
      Yanik
      Yes, but there is NO syntax problem.
      I changed one character, updated the iRule and got syntax error, then I changed the character back and the LTM saved the iRule well.
