Alan_Evans_1020
Apr 07, 2009iRule (HTTP) to select pool based on URI then continue using that pool for duration of session
I am working on a HTTP iRule where I want to create an iRule that selects a pool based on an entry URI and then have the HTTP session continue using that pool and redirect the user to a regular URI for the service.
In the setup:
SYSTEM
BIG-IP 9.4.4
POOLS
pool_prod (contains nodes prod1..n)
pool_dev (contains nodes dev1..n)
pool_train (contains nodes train1..n)
VIRTUAL SERVERS
vs_site_http - listening on port 80, just does redirects to https (DONE)
vs_site_https - should send traffic to pools based on entry URI (LB is terminating SSL)
INTENDED BEHAVIOR
SCENARIO 1
1. user1 enters on site.com/prod/
2. lb assigns the session to the prod pool
3. lb redirects the user to site.com/servlet/somejsp
4. user1's browser goes to site.com/servlet/somejsp
5. lb having seen user1 enter on /prod/ sends traffic to prod pool
SCENARIO 2
1. user2 enters on site.com/dev/
2. lb assigns session to the prod pool
3. lb redirects user to site.com/servlet/somejsp
4. user2's browser goes to site.com/servlet/somejsp
5. lb having seen user2 enter on /dev/ sends traffic to dev pool
SCENARIO 3
1. user3 enters on site.com/
2. lb treats / URI as /prod/ URI, does like scenario 1
I can persist on cookies, SSL, source or whatever. Pretty flexible, just need to keep a session tied to a pool without expecting the information to be in every requested URI, just the first.
Seems like, excuse the meta code...
HTTP_REQUEST {
if session not already seen {
select the beginning of URI from class or switch on it
set a cookie or create a persistence table entry
send a redirect
It looks like 'persist add' might be all I need, but the wiki page is a little terse and I am still looking for other docs. Is persistence smart enough to keep a connection in a pool and assigned to a specific node?
Can anyone help me out?
- Alan_Evans_1020
Hmm... Guess I didn't need the smiley on the post. Sorry, don't spend much time in forums. - hoolio
'Persist add' is a generic way to manually insert a persistence record. It doesn't actually include the persistence method.
I think using a cookie per pool would be a good method for this scenario. However, I'm not sure I understand the full scenario. Would a client ever start with a request which is sent to one pool and then during the same browser session make a request which goes to another pool? If so, would you want to remove any previously set cookies, so the client would be sent to the most recently selected pool for requests which don't have a corresponding URI to pool mapping in the class?
I'd think the logic would be something like this:when HTTP_REQUEST { If request is to a path which has a corresponding path to pool mapping Select this pool Use cookie insert persistence for this pool (persist cookie insert "pool_A_cookie") Set a variable to track that we're using this pool Else request is not to a path which has a corresponding path to pool mapping, check for pool cookie If any pool cookie exists Select this pool Use cookie insert persistence for this pool (persist cookie insert "pool_X_cookie") Set a variable to track that we're using this pool Else no pool cookie, so take some default action like select default pool, redirect client or send HTTP response? } when LB_FAILED { If pool is down, do something like select default pool, redirect or send HTTP response? Else if pool is up, reselect a different pool member? } when HTTP_RESPONSE { Expire all the other pool cookies based on the variable which tracks the currently used pool }
Aaron - Alan_Evans_1020
A few tweaks still to be done but this is the basis of what I am using.when HTTP_REQUEST { set lb_persist [LB::persist] set lb_server [LB::server addr] set lb_key [LB::persist key] set http_uri [HTTP::uri] log local0. "persist: [LB::persist] server: $lb_server uri: $http_uri" if { [LB::server addr] eq "" }{ if { [HTTP::path] starts_with "/dev" } { pool pool_dev eval [LB::select] persist cookie HTTP::redirect https://[HTTP::host]/?[HTTP::query] } elseif { [HTTP::path] starts_with "/train" } { pool pool_train eval [LB::select] persist cookie HTTP::redirect https://[HTTP::host]/?[HTTP::query] } elseif { [HTTP::path] starts_with "/prod" } { pool pool_prod eval [LB::select] persist cookie HTTP::redirect https://[HTTP::host]/?[HTTP::query] } } }
