barry_8239
Nov 30, 2012irule http redirect help
Hi All, i am fairly new to F5 world and need some assistance in redirecting a url. I've tried the following, but the browser will still show http://example/test and not the new url http://newserver/test. Any helpo is much appreciated.
if{ [HTTP::host] contains "example/test"} {
HTTP::redirect http://newserver/test[HTTP::uri]
- What_Lies_Bene1
Try this;when HTTP_REQUEST { if { [HTTP::host] contains "example/test" } { HTTP::redirect "http://newserver/test[HTTP::uri]" } } - What_Lies_Bene1
I'm not sure why you're adding the old URI to the new, this might work better;when HTTP_REQUEST { if { [HTTP::host] contains "example" } { HTTP::redirect "http://newserver[HTTP::uri]" } } - What_Lies_Bene1
I'm not sure why you're adding the old URI to the new, this might work better;when HTTP_REQUEST { if { [HTTP::host] contains "example" } { HTTP::redirect "http://newserver[HTTP::uri]" } } - barry_8239
You are the best!! That was it! Thank you very much. Redirect works like a charm.
Thanks again
- barry_8239
I have it halfway working now. IS there a way to add another host name to the above irule?
The redirect works when entering example in the browser, but i also need to add "sample" as well. Would the following work? When i put sample in the url i get an iis page and not redirected to newserver.
if { [HTTP::host] contains "example" or "sample" } {
} - What_Lies_Bene1
Sure, try this;when HTTP_REQUEST { switch -glob [string tolower [HTTP::host]] { "example*" - "sample" { HTTP::redirect "https://otherserver.com[HTTP::uri]" } } - barry_8239
i get all sort of parameter errors when i do an update after adding the rule - barry_8239
This is what i tried to add
"example*" -
"sample" {
} - What_Lies_Bene1
Sorry, missing the last bracket;when HTTP_REQUEST { switch -glob [string tolower [HTTP::host]] { "example*" - "sample" { HTTP::redirect "https://otherserver.com[HTTP::uri]" } } }
