TNY_122436's avatar
TNY_122436
Oct 28, 2013
iRule Help
I'm trying to create a rule that will do redirections base on certain words are contain in the URI, but not sure where to start or what is going on as only one argument is working (test.123.tree) and the two other isn't working. Is there something wrong with my code?Here is the scenerio:
When a end user enters these variations in the URL, it will redirect to a abc pool. Otherwise, all else goes to xyz pool
test.123.com/nice* test.123.com/tree* test.123.com/green* redirect it to abc pool
Otherwise, everything else goes into xyz pool
     if {[string length [HTTP::host]]}{
       Redirect to the requested host and URI (minus the port if specified)
      if {[HTTP::uri] contains "nice"} {
      pool abc }
      elseif {[HTTP::uri] contains "green"} {
      pool abc }
      elseif {[HTTP::uri] contains "tree"} {
      pool abc }
       Redirect to this Pool Member
      pool xyz
  • Try this:
        switch -glob [string tolower [HTTP::uri]] {
            "/nice*" -
            "/green*" -
            "/tree*" { pool abc }
            default { pool xyz }
