Qamar_Zia_13515
Jun 01, 2014IRULE Help
I need IRULE help to acheive the below requirement:
Request for (abc.gov.us) Redirect to (abc.us)
Request for ecouncil.us (abc.encouncil.us)
Appreciate if some one help me out at the earliest, need to acheive both redirections in the same IRULE.
Regards,
- The_Bhattman
Hi Qamar,
I think you are looking for something like the following:
when HTTP_REQUEST { if {[HTTP::uri] eq "/" } { switch -glob [string tolower [HTTP::host]] { "abc.gov.us" { HTTP::redirect "http://abc.us[HTTP::uri]" } "ecouncil.us" { HTTP::redirect "http://abc.encouncil.us[HTTP::uri]" } } } }I hope this helps,
-=Bhattman=-
Try this one:
when HTTP_REQUEST { set host [string tolower [HTTP::host]] switch $host { "abc.gov.us" { HTTP::respond 301 Location "http://abc.us" } "ecouncil.us" { HTTP::respond 301 Location "http://abc.ecouncil.us" } } }/Patrik
- nitass
Employee
e.g.
[root@ve11a:Active:In Sync] config tmsh list ltm rule qux ltm rule qux { when HTTP_REQUEST { if { [HTTP::uri] eq "/" } { switch [HTTP::host] { "abc.gov.us" { HTTP::redirect "http://abc.us/" } "abc.encouncil.us" { do something" } default { do somethingelse } } } } } [root@ve11a:Active:In Sync] config curl -I http://172.28.24.10 -H "Host: abc.gov.us" HTTP/1.0 302 Found Location: http://abc.us/ Server: BigIP Connection: Keep-Alive Content-Length: 0
