Snl
Oct 18, 2018Irule help
Folks
I have requirement to the request start with /abc/ directory and contains the parameter si or di the value of this parameter should not exceed more than 50 characters , if exceed should drop if less should allow. cheers snl
- Snl
done some research found below , how i can call the parameters in this particular those 2 value
when RULE_INIT { set DEBUG 1 set sec_http_max_post_data_length 50 } when HTTP_REQUEST { if { [string tolower [HTTP::uri]] equals "/abc/" and [HTTP::method] equals "POST" } { set len [HTTP::header "Content-Length"] if { [expr $len > $::sec_http_max_post_data_length] } { log local0. " SEC-ALERT: POST Length: uri=[HTTP::uri]; len=$len; max_len=$::sec_http_max_post_data_length" reject } } } } - Kevin_Stewart
Employee
You'll want to create static variables in RULE_INIT to maintain CMP.
when RULE_INIT { set static::DEBUG 1 set static::sec_http_max_post_data_length 50 } when HTTP_REQUEST { if { ( [string tolower [HTTP::uri]] equals "/abc/" ) and ( [HTTP::method] equals "POST" ) } { set len [HTTP::header "Content-Length"] if { [expr {$len > $static::sec_http_max_post_data_length}] } { log local0. " SEC-ALERT: POST Length: uri=[HTTP::uri]; len=$len; max_len=$static::sec_http_max_post_data_length" reject } } }
