iRule help to restrict access to particular URI on vserver
I've been asked to restrict access to a site's "/admin" page to only the networks/IPs used by support techs. I was thinking a redirect to the primary site ("mysite.com" for the example) for such traffic would work fine, using an irule to do it.
Basically... When an HTTPS request containing "mysite.com/admin" comes in, and it's NOT coming from 175.100.50.0 OR 200.20.10.18 (example IPs, btw), then redirect to ";
Can any of the iRule senseis help me?
Thanks!
- jaikumar_f5
Noctilucent
Hey Alan,
Try this, make sure you create a Datagroup of admin_ips and add your require subnets in there, you can change the operator "starts_with" to something else (equals/contains) to match your requirements in future.
when HTTP_REQUEST { if { [HTTP::uri] starts_with "/admin" and (![class match [IP::remote_addr] equals admin_ips]) } { HTTP::redirect "https://mysite.com" } } - Snl
ensure to add stringtolower to avoid case sensitive bypass
when HTTP_REQUEST { if { [string tolower [HTTP::uri] starts_with "/admin" and (![class match [IP::remote_addr] equals admin_ips]) } { HTTP::redirect "https://mysite.com" } }
