iRule help to allow 2 ip's only
Hello I have a question regarding packet filtering and need help with simple iRule help I need to allow 2 ip's only to acesss a VIP.
If I use packet filtering it applies to all the VIP's correct? If yes what is the point using packet filtering?
iRule help I need is as below - (Will the below work) I need client with 1.1.1.1 and 2.2.2.2 to access the VIP.
when CLIENT_ACCEPTED {
if { ![IP::addr [IP::client_addr] equals 1.1.1.1] or [IP::client_addr] equals 2.2.2.2] }{ discard } else {
log local0. "Allowed Traffic" } }
- ekaleido
Cirrus
Create an IP datagroup containing the IPs you want to allow, then try this...
when CLIENT_ACCEPTED { set yesno [class match [IP::client_addr] equals "allowed_ip"] switch $yesno { "" { discard } default { log local0. "Accepted client from [IP::client_addr" } } } Hi,
Packet filter apply to vlans. It's more general than just blocking access to those 2 IPs on a single Virtual Server.
Your simple irule can do the trick without enabling Packet filter. You just have a small issue in the if condition :
when CLIENT_ACCEPTED { if { !([IP::client_addr] eq "1.1.1.1" or [IP::client_addr] eq "2.2.2.2") } { discard } else { log local0. "Allowed Traffic" } }
