krisdames2
Altostratus
Sep 20, 2022irule help - pool command and ERR_RTE Routing problem
I am running on 14.1.4 and I have an iRule on an HTTPS virtual in route domain 1 with an iRule to do content switching based on URI. The new pool I am switching to has members that require SNI. It is...
Sep 20, 2022
Hello,
Did you add all of the SSL profiles to the virtual servers (in case there is is a default one), did you add the server name inside the SSL profile used?
take a look at this article, it might be useful.
https://support.f5.com/csp/article/K13452#p4
krisdames
Cirrus
Sep 20, 2022.
