irule help - pool command and ERR_RTE Routing problem
Hello,
Did you add all of the SSL profiles to the virtual servers (in case there is is a default one), did you add the server name inside the SSL profile used?
take a look at this article, it might be useful.
https://support.f5.com/csp/article/K13452#p4
- krisdamesSep 20, 2022
Cirrus
- krisdames2Sep 20, 2022
Altostratus
Mohamed_Salah_,
I only have one SSL server profile attached to the virtual. Are you suggesting additional profiles must be attached to the virtual if I want to call them in an iRule with SSL::profile? The SSL server profile that I am calling in my iRule does have the server name that the new pool members need.
- Sep 20, 2022
I think you should start considering generating a new tcpdump and decrypting the traffic using the below article.
tcpdump -nnnveti 0.0:nnnp host "client IP" and port 443 -s0 -S -w /var/log/pcapname.pcap
Decrypt traffic and assign the irule on the virtual server:
https://support.f5.com/csp/article/K12783074
