Kiran_125879
Apr 22, 2013iRule for uri rewrite only for selected uri paths and keep the same url for all other cases
Hi Friends,
Could anyone please suggest me an iRule which will only rewrite uris for selected uri paths and keep the original url same for all other cases.
ex: I want the uris to be rewritten only for the below 2 cases and all other cases should be kept as is.
domain.com/abc -> domain.com/hij
domain.com/def -> domain.com/klm
All other request should be same such as if the original request is domain.com/123 -> it should remain same as domain.com/123
Any help would be greatly appreciated.
Regards
Kiran
- nitass
Employee
e.g.[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.252:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b pool foo list pool foo { members 200.200.200.101:80 {} } [root@ve10:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { switch [string tolower [HTTP::uri]] { "/abc" { HTTP::uri "/hij" } "/def" { HTTP::uri "/klm" } } } } /abc [root@ve10:Active] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.19.251(50703) <-> 172.28.19.252(80) 1366693438.9012 (0.0010) C>S --------------------------------------------------------------- GET /abc HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Accept: */* Host: domain.com --------------------------------------------------------------- New TCP connection 2: 200.200.200.10(50703) <-> 200.200.200.101(80) 1366693438.9033 (0.0018) C>S --------------------------------------------------------------- GET /hij HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Accept: */* Host: domain.com --------------------------------------------------------------- /something else [root@ve10:Active] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.19.251(50704) <-> 172.28.19.252(80) 1366693465.1440 (0.0009) C>S --------------------------------------------------------------- GET /somethingelse HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Accept: */* Host: domain.com --------------------------------------------------------------- New TCP connection 2: 200.200.200.10(50704) <-> 200.200.200.101(80) 1366693465.1451 (0.0010) C>S --------------------------------------------------------------- GET /somethingelse HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Accept: */* Host: domain.com ---------------------------------------------------------------
