Meshal_119384's avatar
Meshal_119384
Jun 29, 2015
Irule for URI redirection working for first session
Hi all ,
I have write irule to forward the traffic based on uri , but when I test it I found that there every session is create two times one flow the irule and second flow the default , here my irule
    when CLIENT_ACCEPTED {
set vip [IP::local_addr]:[TCP::local_port]
     if  { [HTTP::uri] contains "/abc" } {
     log local0. "[IP::client_addr]:[TCP::client_port] [IP::local_addr]:[TCP::local_port]"
        pool POOL_1
    else {
        pool POOL_2
     log local0. "NOT matched , default POOL [IP::client_addr]:[TCP::client_port] [IP::local_addr]:[TCP::local_port]"
when SERVER_CONNECTED {
    log local0. "Connection from [IP::client_addr]:[TCP::client_port] to VIP $vip To Node [IP::server_addr]:[TCP::server_port] established."
and here the logs
     1.1.1.1%10:65437 10.10.10.10%10:5291
  Connection from 1.1.1.1%10:65437 to VIP 10.10.10.10%10:5291 To Node 10.10.10.20%10:6102 established.
 NOT matched , default POOL 1.1.1.1%10:65438 10.10.10.10%10:5291
  Connection from 1.1.1.1%10:65438 to VIP 10.10.10.10%10:5291 To Node 10.10.10.20%10:6100 established.
  • nathe's avatar
    nathe
    What happens if you use fiddler or http fox to see what http requests are being sent? also, you can log the HTTP::uri too for further information in the ltm log.
    N
