Ibrahim_Kadiri's avatar
Ibrahim_Kadiri
Jun 12, 2017
Irule for TCP DATA verification
Hi Experts,
I have created the below iRule, Kindly can you please suggest to tune it.
I am looking for three conditions to match in a connection to allow the user. For Eg: The Client ID (TID) should be Equal to Serial Number (TSN) and its MAC (MAC)
when CLIENT_ACCEPTED {
    TCP::collect
when CLIENT_DATA {
set payload [TCP::payload]
regexp {} payload TID
regexp {} payload TSN
set TSN "$TSN,"
set MAC LINK::lasthop
concatenate the two variables
set total "$TSN$MAC"
set value [class match -name $TID equals string_Data_group ]
if {$value ne $total}{
    reject
Thanks,
Ibrahim
  • Hi,
    The main problem in your irule is the regexp command twice of all payload data for any TCP .
    What is the regexp pattern? this seems empty. can you search pattern without regex (string with fixed length, encoded string length in headers, ...)?
