miodas's avatar
miodas
5 years ago
iRule for static traffic distribution
Hello @LL
Me and my colleague we manage to write this iRule and it looks like its working so far :
 if { [IP::addr [IP::client_addr] equals 192.168.199.251] } {
    if { [LB::status pool pool_crm_prod_https member 192.168.199.163 443] ne "down" } {
         # Exit this event from this rule
         return
      } elseif {[LB::status pool pool_crm_prod_https member 192.168.199.186 443] ne "down" } {
         return
 } elseif  { [IP::addr [IP::client_addr] equals 192.168.199.252] } {
    if { [LB::status pool pool_crm_prod_https member 192.168.199.186 443] ne "down" } {
         return
      } elseif {[LB::status pool pool_crm_prod_https member 192.168.199.163 443] ne "down" } {
         return
 } elseif { [string tolower [HTTP::uri]] starts_with "/isvroot/" } {
                                pool pool_crm_prod_8888
 } elseif { [string tolower [HTTP::uri]] starts_with "/isvroot2/" } {
                                pool pool_crm_prod_9999
#Default to load balancing all users
#when HTTP_REQUEST {
#	if { [string tolower [HTTP::uri]] starts_with "/isvroot/" } {
#		pool pool_crm_prod_8888 }
#    elseif { [string tolower [HTTP::uri]] starts_with "/isvroot2/" } {
#                pool pool_crm_prod_9999 }
#	else {
#		pool pool_crm_prod_https }
We were able to test it in our small test environment.
Recently customer decided that they need to add another servers and our test environment doesn't have option to test new iRule.
We want to force LB to statically distribute traffic this way :
wcf1 192.168.199.251 --> crm1 192.168.199.176
wcf2 192.168.199.252 --> crm2 192.168.199.163
wcf3 192.168.199.30 --> crm3 192.168.199.186
If it comes to VIP setup :
443/HTTPS
default persistence - cookie
fallback persistence - source addr
Can anyone tell me if this will work :
    if { [LB::status pool pool_crm_prod_https member 192.168.199.176 443] ne "down" } {
         return
      } elseif {([LB::status pool pool_crm_prod_https member 192.168.199.163 443] ne "down") or ([LB::status pool pool_crm_prod_https member 192.168.199.186 443] ne "down") } {
         return
         return
      } elseif {([LB::status pool pool_crm_prod_https member 192.168.199.176 443] ne "down") or ([LB::status pool pool_crm_prod_https member 192.168.199.186 443] ne "down") } {
         return
 } elseif  { [IP::addr [IP::client_addr] equals 192.168.199.30 ] } {
    if { ([LB::status pool pool_crm_prod_https member 192.168.199.186 443] ne "down") } {
         return
	  } elseif {([LB::status pool pool_crm_prod_https member 192.168.199.163 443] ne "down") or ([LB::status pool pool_crm_prod_https member 192.168.199.176 443] ne "down") } {
         return
