irule for SIP forward
we have an irule to forward SIP rule SIP-forward { when SIP_REQUEST_SEND { SIP::header insert "Record-Route" "" } when SIP_RESPONSE_SEND { if { [SIP::header "Record-Route"] ne "" }{ SIP::header remove "Record-Route" SIP::header insert "Record-Route" "" } } }
but now we have a new requirment that SIP_RESPONSE_SEND header has the following Route header , sip:xxxxxx.
we want to remove , could the following work? if { [SIP::header " Route"] ne "" }{ SIP::header remove "Route" "" }
- VernonWells
Employee
The SIP::header remove method takes one of these two forms:
SIP::header remove SIP::header removeThus, if you are attempting to remove a specific Route header, and there may be more than one, then the form you provide will unfortunately not work. You must iterate through the Route headers until you find the position of the header to remove. In 11.6, something like this might do it:
set required_value "" for { set i 0 } { $i < [SIP::header count Route] } { incr i } { if { [SIP::header value Route $i] eq $required_value } { SIP::header remove Route $i break } }Before 11.6, this may do it:
set required_value "" set i 0 while { 1 } { switch [SIP::header value Route $i] { "" { break } $required_value { SIP::header remove Route $i break } } }I'm not sure whether the SIP::header sub-commands start at 0 or start at 1. If they start at 1, you'd have to adjust the code. And, I'll have to admit that I've not tested this, so ... good luck :).
- eooyc_209394
Thank you for your reply. I just confirmed the route header is only one, not two. like this route , sip:xxxxxx
not route route sip:xxxxxx
whether your code work?
also, we want to make the rule remove "," when only the sip:xxxxx contains special ip range. could you give me some suggestion? thank you very much.
- VernonWells
Employee
Yes, I see now from RFC 3261 that the Route header is a comma-delimited list. The RFC is a bit ambiguous about spaces (i.e., route,route is clearly acceptable, but is route, route also acceptable?), so as a simplification, I'll assume whitespace is not permitted between list elements. I will also assume that the Route header is not repeated. If it is, then you'll have to mix-in the logic above. I assume that there can be more than one instance of the route you wish to remove. If that's not the case, the logic can be somewhat simplified. Finally, I use a Data Group (called
dg-route-blocks-to-remove) to match IP addresses in the Route entries.when RULE_INIT { set static::srm_route_remove_data_group "dg-route-blocks-to-remove" } when SIP_REQUEST { set route_list [split [SIP::header Route] ,] for { set i 0 } { $i < [llength $route_list] } { incr i } { set ip [getfield [lindex $route_list $i] : 2] if { [class match $ip equals $static::srm_route_remove_data_group] } { lset route_list $i "" } } if you are using 11.6, you may substitute "SIP::header replace" here SIP::header remove Route SIP::header insert Route [join [lsearch -all -inline -not $route_list ""] ,] }I will once again admit that I have not tested this rule. Let me know if it bombs somehow.
- VernonWells
Employee
I tested this and it works (the way I expect, at least). Here is an example
tmshcommand for creating the Data Group:tmsh create ltm data-group internal dg-route-blocks-to-remove \ type ip records add { 10.10.210.0/24 { } 192.168.5.0/25 { } }Naturally, you would substitute your own set of netblocks.
Do keep in mind that this mechanism will always move the Route header to the end of the message header set (in 11.6, using the SIP::header replace method avoids this).
As an example, using the Data Group definition above, I sent the following SIP Request through a Virtual Server with the iRule above attached:
REGISTER sips:ss2.biloxi.example.com SIP/2.0 Via: SIP/2.0/TLS client.biloxi.example.com:5061;branch=z9hG4bKnashd92 From: Bob ;tag=ja743ks76zlflH To: Bob Call-ID: [email protected] CSeq: 2 REGISTER Route: ,,, Content-Length: 0and this is the message that arrives at the Pool Member:
REGISTER sips:ss2.biloxi.example.com SIP/2.0 Via: SIP/2.0/TLS client.biloxi.example.com:5061;branch=z9hG4bKnashd92 From: Bob ;tag=ja743ks76zlflH To: Bob Call-ID: [email protected] CSeq: 2 REGISTER Content-Length: 0 Route: ,
