JamesB12's avatar
JamesB12
Jun 05, 2020
iRule for Reverse Proxy with data-group
The below URL to be restricted to the specific set of IP addresses.
https://pbr.corp.com/exp-int-lifetime-mgmt/v1/sit
Also would like to match the complete URI in HTTP rather than the keywords.
but the main URL <https://pbr.corp.com/> should be accessible for Anybody.
Any help much appreciated...Thanks.
  • Hello,
    iRule given in below post should fulfill your requirement.
    ​https://devcentral.f5.com/s/question/0D51T00007Xf8lOSAR/reverse-proxy-irule-to-restrict-the-access-on-ip?page=3
    Hope it works!
    Mayur​
  • Hello,
    No, you can't use it in that way. You can use statement like given below,
    if { [HTTP::host] equals "pbr.corp.com" and [HTTP::uri] equals "/exp-int-lifetime-mgmt/v1/sit" }
    Hope it helps!
    Mayur
