iRule for LB between few servers and tcp range ports on each server
I need to configure iRule for LB between few servers and tcp range ports on each server
Voip component will send tcp packet (always port 5060) to F5 VIP F5 will take the tcp5060 and send it to destination servers and change the destination port between range 5040 to 5048 (5040,5042,5044,5046,5048) The return packet should be with the relevant port .
For example :
First packet : voip device --> tcp 5060 --> F5 VIP --> tcp 5040 --> destination server1 Return packet --> tcp5040 Second packet : voip device --> tcp 5060 --> F5 VIP --> tcp 5042 --> destination server 1 Return packet --> tcp5042 Third packet : voip device --> tcp 5060 --> F5 VIP --> tcp 5044 destination server1 Return packet --> tcp5044
And so on till port 5048 .
After finished all ports range on server1 F5 will start the same for server2 .
Please advise how we can do it .
Thanks Shai
- The_Bhattman
Hi Shaig,
You can populate the pool with destination servers on the range of ports you would like. Make sure the translation is turned on the VIP.
For example:
VIP IP:5060 --> Pool Member 1: SERVERIP1:5040
VIP IP:5060 --> Pool Member 2: SERVERIP1:5042
VIP IP:5060 --> Pool Member 3: SERVERIP1:5044
VIP IP:5060 --> Pool Member 4: SERVERIP1:5046
VIP IP:5060 --> Pool Member 5: SERVERIP1:5048
VIP IP:5060 --> Pool Member 6: SERVERIP2:5040
VIP IP:5060 --> Pool Member 7: SERVERIP2:5042
VIP IP:5060 --> Pool Member 8: SERVERIP2:5044
VIP IP:5060 --> Pool Member 9: SERVERIP2:5046
VIP IP:5060 --> Pool Member 10: SERVERIP2:5048
-=Bhattman=-
